[Flash-X-users] Getting Flash-X to work
Ryan Farber rjfarber at umich.edu
Wed Aug 28 23:07:22 CDT 2024
Hi Peter,
1. Less of a Flash-X suggestion as much as personal life philosophy: yes
sometimes the best path forward is a fresh (re)start. Along that vein, I've
started the process of typing up a list of steps I need(ed) to take to "Get
Flash-X to work" on my ubuntu virtual private server (which is definitely
more of a pain since no packages are provided for me, but on the plus side
I have full control over everything). I'm currently building lapack. (Will
finish after I go to sleep likely.)
2. I don't know that you have to start over. Kiya mentioned two potentially
helpful suggestions
i. Try changing " thornadoOrder=ORDER_1" in your setup line to a different
value
ii. In your object directory, type "ls -l *.F90 > Flash-X-files.txt" and
share that file with us. Then we can see if you the setup line correctly
placed the files you need in the object directory, or if some are missing.
Best wishes,
Ryan
On Wed, Aug 28, 2024 at 8:28 AM Peter Manzella <peter.manzella at maine.edu>
wrote:
> Kiya & Ryan,
> I finally got the chance to take a look at this, and what I'm gathering is
> that my installation of thornado is not correct. I am not sure how to
> troubleshoot this beyond "uninstall and reinstall" which I can assume is
> not the way to go about this. Ryan mentioned that it may not be in the
> proper system PATH, I'm assuming this could be corrected in the makefile
> that is in the "sites" directory?
> I do hope that my struggles prove to be useful and helpful for those in
> the future, so I very much thank you all for your help.
> On Tue, Aug 27, 2024 at 12:42 AM kiyarash Taghiniyarami <
> kiyarash.niyarami at gmail.com> wrote:
>> Dear Peter & Ryan,
>> No problem. I am just trying to help and hope it will be useful.
>> I see in your setup syntax Thornado order is set to 1. Order one is not
>> working properly (some files are missing in thornado order1 directory)
>> since I asked Austin so far, he mentioned they tried to use orderV and then
>> in flash.par setting v = 0.0 gives the same result as order1. So I am
>> afraid Peter your setup is not complete yet and because of that
>> wlEOSInversionModule.F90 is missing in the directory created by setup,
>> check that out again.
>> If you get ls of the obj directory (or whatever created by setup) you
>> could see list of codes linked there and check if wlEOSInversion in present
>> there or not.
>> Best,
>> Kiya
>> On Tue, Aug 27, 2024 at 6:31 AM Peter Manzella <peter.manzella at maine.edu>
>> wrote:
>>> Ryan, Of course, many many thanks to Kiya, been extremely helpful. And
>>> many thanks to you for lending a helping hand too! I didn't see your email
>>> till very much after I had left my office, but noticed it and had to come
>>> in to take care of
>>> ZjQcmQRYFpfptBannerStart
>>> This Message Is From an External Sender
>>> This message came from outside your organization.
>>> ZjQcmQRYFpfptBannerEnd
>>> Ryan,
>>> Of course, many many thanks to Kiya, been extremely helpful. And many
>>> thanks to you for lending a helping hand too! I didn't see your email till
>>> very much after I had left my office, but noticed it and had to come in to
>>> take care of some other things, so it is a bit late, sorry.
>>> As asked (let me know if I didn't grab the right thing)
>>> 1) screenshot of 'ls' in the problem directory:
>>> [image: image.png]
>>> 2) my setup command:
>>> ./setup Relaxation -auto -3d +cartesian +cube16 +thornado nE=16 swE=0
>>> nSpecies=6 nNodes=2 nMoments=4 momentClosure=MINERBO thornadoOrder=ORDER_1
>>> +weaklib -parfile=flash.par
>>> 3)full output in a compile.txt
>>> I really appreciate any and all help I can get, I've spent a bit on
>>> trying to get through it, but quite often it felt like I was going in
>>> circles.
>>> On Mon, Aug 26, 2024 at 4:42 PM Ryan Farber <rjfarber at umich.edu> wrote:
>>>> Hi Peter,
>>>> If you share the following I can take a look tonight:
>>>> 1) screenshot of “ls” in your problem directory
>>>> 2) your setup command
>>>> 3) the full output and error streams of your compilation command (e.g., make
>>>> 2>&1 compile.txt
>>>> As an aside, thanks to Kiya for your kind contributions to this thread!
>>>> I’m sure what you've provided will be useful in the future too!
>>>> Best wishes,
>>>> Ryan
>>>> Sent from my iPhone
>>>> On Aug 26, 2024, at 1:53 PM, Peter Manzella <peter.manzella at maine.edu>
>>>> wrote:
>>>> OK, that makes more sense, I'll need to make sure those are in the
>>>> file, not command line. I went to setup after adding those, and have this
>>>> error, its related to equation of state, and I haven't been able to find
>>>> anything in documentation
>>>> anything in documentation about it.
>>>> <image.png>
>>>> This is the sort of thing that is frustrating, not being able to find
>>>> where I need to look to troubleshoot. I tried using grep to find it, I've
>>>> looked in the documentation link you sent me (I already knew about that,
>>>> but it wasn't helpful beyond the quick start), but couldn't find it. Is
>>>> this more of a thornado issue? Cause like I said I'm not super acquainted
>>>> with large codes that require so many moving pieces.
>>>> On Mon, Aug 26, 2024 at 2:28 PM kiyarash Taghiniyarami <
>>>>> Dear Peter,
>>>>> These are not for command line (If you mean "command line" as setup
>>>>> for configuring a new run).
>>>>> Before setup you need to make a directory in the Simulation unit
>>>>> (/source/Simulation/SimulationMain). In that directory you need some codes
>>>>> such as Simulation_data.F90, Simulation_init.F90, Simulation_initBlock.F90,
>>>>> and etc.
>>>>> Say you need the "Half" variable in the Simulation_initBlock.F90. you
>>>>> can call it by KindModule from Thornado if you write the following in that
>>>>> fortran code:
>>>>> Use KindModule, only: Half
>>>>> so you can use the "Half" anywhere in that Simulation_initBlock.F90.
>>>>> It has nothing to do with typing in the command line and hitting enter.
>>>>> If I understand correctly what you mean, there are some setup
>>>>> variables you can type in the command line (such as nxb,nyb, swE,nE and
>>>>> etc.) which are different from modules. setup variables can be set up in
>>>>> Config files in any physics subdirectories.
>>>>> There is documentation for Flashx as well:
>>>>> https://urldefense.us/v3/__https://flash-x.github.io/Flash-X-docs/*__;Iw!!G_uCfscf7eWS!eWx-W5LDVabQFh_r_2l82Ouaf6vS8I2ikwgIehXDK_BLJpysI-dofuQIDy2Jg1WiChzifZM1v3vJqzJ8WId2nwRYjHT1QXHDiQ$
>>>>> <https://urldefense.us/v3/__https://flash-x.github.io/Flash-X-docs/*__;Iw!!G_uCfscf7eWS!cy5tKVb9Qwu2rLLCi1LNfkq2D5uVYlmB4FWF6x2Pvqvq1OrrRPvzAwx-yFHLivQcBbWQTRySdjTQzVXdJjzC_Qh1vl2zpGdoLrGAwyOT$>
>>>>> Kind regards,
>>>>> Kiya
>>>> Peter Manzella
>>>> PhD Candidate, Department of Physics and Astronomy
>>>> 309 Bennett Hall
>>>> University of Maine
>>>> “If you run out of ideas follow the road; you'll get there.” – Edgar
>>>> Allan Poe
>>>> Flash-X-users mailing list
>>>> Flash-X-users at lists.cels.anl.gov
>>>> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!eWx-W5LDVabQFh_r_2l82Ouaf6vS8I2ikwgIehXDK_BLJpysI-dofuQIDy2Jg1WiChzifZM1v3vJqzJ8WId2nwRYjHS28-3o6A$
>>>> <https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!Z1_GXydE2pV62oyGpM2ZteP_zTQdp-c9MRnUEZgvDy2eM0cBnqD656HBLPAkAMqZu7096jmjWOZzHL2ARHhx_LB-ZMcFtJGRTFtRFBtj$>
>>> Peter Manzella
>>> 309 Bennett Hall
>>> University of Maine
>>> Allan Poe
> Peter Manzella
> 309 Bennett Hall
> University of Maine
> “If you run out of ideas follow the road; you'll get there.” – Edgar Allan
> Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240828/939d51b7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240828/939d51b7/attachment-0001.png>
More information about the Flash-X-users mailing list
