[Flash-X-users] Getting Flash-X to work
Peter Manzella
peter.manzella at maine.edu
Mon Aug 26 22:00:59 CDT 2024
Ryan,
Of course, many many thanks to Kiya, been extremely helpful. And many
thanks to you for lending a helping hand too! I didn't see your email till
very much after I had left my office, but noticed it and had to come in to
take care of some other things, so it is a bit late, sorry.
As asked (let me know if I didn't grab the right thing)
1) screenshot of 'ls' in the problem directory:
[image: image.png]
2) my setup command:
./setup Relaxation -auto -3d +cartesian +cube16 +thornado nE=16 swE=0
nSpecies=6 nNodes=2 nMoments=4 momentClosure=MINERBO thornadoOrder=ORDER_1
+weaklib -parfile=flash.par
3)full output in a compile.txt
I really appreciate any and all help I can get, I've spent a bit on trying
to get through it, but quite often it felt like I was going in circles.
On Mon, Aug 26, 2024 at 4:42 PM Ryan Farber <rjfarber at umich.edu> wrote:
> Hi Peter,
> If you share the following I can take a look tonight:
> 1) screenshot of “ls” in your problem directory
> 2) your setup command
> 3) the full output and error streams of your compilation command (e.g., make
> 2>&1 compile.txt
> As an aside, thanks to Kiya for your kind contributions to this thread!
> I’m sure what you've provided will be useful in the future too!
> Best wishes,
> Ryan
> Sent from my iPhone
> On Aug 26, 2024, at 1:53 PM, Peter Manzella <peter.manzella at maine.edu>
> wrote:
> OK, that makes more sense, I'll need to make sure those are in the file,
> not command line. I went to setup after adding those, and have this error,
> its related to equation of state, and I haven't been able to find anything
> in documentation
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> in documentation about it.
> <image.png>
> This is the sort of thing that is frustrating, not being able to find
> where I need to look to troubleshoot. I tried using grep to find it, I've
> looked in the documentation link you sent me (I already knew about that,
> but it wasn't helpful beyond the quick start), but couldn't find it. Is
> this more of a thornado issue? Cause like I said I'm not super acquainted
> with large codes that require so many moving pieces.
> On Mon, Aug 26, 2024 at 2:28 PM kiyarash Taghiniyarami <
> kiyarash.niyarami at gmail.com> wrote:
>> Dear Peter,
>> These are not for command line (If you mean "command line" as setup for
>> configuring a new run).
>> Before setup you need to make a directory in the Simulation unit
>> (/source/Simulation/SimulationMain). In that directory you need some codes
>> such as Simulation_data.F90, Simulation_init.F90, Simulation_initBlock.F90,
>> and etc.
>> Say you need the "Half" variable in the Simulation_initBlock.F90. you can
>> call it by KindModule from Thornado if you write the following in that
>> fortran code:
>> Use KindModule, only: Half
>> so you can use the "Half" anywhere in that Simulation_initBlock.F90. It
>> has nothing to do with typing in the command line and hitting enter.
>> If I understand correctly what you mean, there are some setup variables
>> you can type in the command line (such as nxb,nyb, swE,nE and etc.) which
>> are different from modules. setup variables can be set up in Config files
>> in any physics subdirectories.
>> There is documentation for Flashx as well:
>> https://urldefense.us/v3/__https://flash-x.github.io/Flash-X-docs/*__;Iw!!G_uCfscf7eWS!Z1_GXydE2pV62oyGpM2ZteP_zTQdp-c9MRnUEZgvDy2eM0cBnqD656HBLPAkAMqZu7096jmjWOZzHL2ARHhx_LB-ZMcFtJGRTH7jzJhH$
>> <https://urldefense.us/v3/__https://flash-x.github.io/Flash-X-docs/*__;Iw!!G_uCfscf7eWS!cy5tKVb9Qwu2rLLCi1LNfkq2D5uVYlmB4FWF6x2Pvqvq1OrrRPvzAwx-yFHLivQcBbWQTRySdjTQzVXdJjzC_Qh1vl2zpGdoLrGAwyOT$>
>> Kind regards,
>> Kiya
> Peter Manzella
> PhD Candidate, Department of Physics and Astronomy
> 309 Bennett Hall
> University of Maine
> “If you run out of ideas follow the road; you'll get there.” – Edgar Allan
> Poe
> Flash-X-users mailing list
> Flash-X-users at lists.cels.anl.gov
> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!Z1_GXydE2pV62oyGpM2ZteP_zTQdp-c9MRnUEZgvDy2eM0cBnqD656HBLPAkAMqZu7096jmjWOZzHL2ARHhx_LB-ZMcFtJGRTFtRFBtj$
Peter Manzella
309 Bennett Hall
University of Maine
Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240826/dce7570f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240826/dce7570f/attachment-0001.png>
Processing Shortcut file:
/home/pmanzella/Flash-X-main-cdalton/bin/setup_shortcuts.txt
checking for needed files and directories
checking sites Aliases file
site directory for site node-107.localdomain not found;
using prototype Linux
generating default Units file
Driver/DriverMain/Unsplit
Grid/GridBoundaryConditions
Grid/GridMain/AMR/Paramesh4/PM4_package/flash_avoid_orrery
Grid/GridMain/AMR/Paramesh4/PM4_package/headers
Grid/GridMain/AMR/Paramesh4/PM4_package/source
Grid/GridMain/AMR/Paramesh4/PM4_package/utilities/multigrid
Grid/GridMain/AMR/Paramesh4/Thornado
Grid/GridMain/AMR/Paramesh4/interpolation/prolong
Grid/GridMain/AMR/Paramesh4/levelFlux
Grid/localAPI
IO/IOMain/hdf5/serial/PM
IO/localAPI
PhysicalConstants/PhysicalConstantsMain
RuntimeParameters/RuntimeParametersMain
Simulation/SimulationMain/Relaxation
TimeAdvance/TimeAdvanceMain/StrangSplit
flashUtilities/contiguousConversion
flashUtilities/general
flashUtilities/interpolation/oneDim
flashUtilities/nameValueLL
flashUtilities/sorting/quicksort
flashUtilities/system/memoryUsage/legacy
monitors/Logfile/LogfileMain
monitors/Timers/TimersMain/MPINative
physics/Eos/EosMain/WeakLib
physics/Hydro/HydroMain/unsplit/OnlyHydro
physics/Hydro/HydroMain/unsplit/levelFlux
physics/Hydro/localAPI
physics/RadTrans/RadTransMain/TwoMoment/Thornado/OMP
physics/RadTrans/localAPI
scanning /home/pmanzella/Flash-X-main-cdalton/object/Units file for included
units
Grid/localAPI
IO/localAPI
Computing default values for options not specified on command line
Using Makefile.h: /home/pmanzella/Flash-X-main-cdalton/sites/Prototypes/Linux/Makefile.h
Generating variants [''] for unit: /home/pmanzella/Flash-X-main-cdalton/source/physics/Eos/EosMain
Generating variants ['OMP'] for unit: /home/pmanzella/Flash-X-main-cdalton/source/physics/RadTrans/RadTransMain/TwoMoment/Thornado
generating Makefile
running /home/pmanzella/Flash-X-main-cdalton/lib/weaklib/build.sh
+ cd source/Distributions/ExternalLibrary
+ make -f Makefile.Flash clean
rm -f libweaklib.a ../../../object/libweaklib.a *.mod ../../../include/*.mod *.o
+ make -f Makefile.Flash -j8 BUILDFLAG=OPT USE_OACC=FALSE USE_OMP_OL=FALSE USE_OMP=FALSE
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlKindModule.f90 -o wlKindModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlGridModule.f90 -o wlGridModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlThermoStateModule.f90 -o wlThermoStateModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlDependentVariablesModule.f90 -o wlDependentVariablesModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlInterpolationUtilitiesModule.F90 -o wlInterpolationUtilitiesModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/OpacitySource/wlOpacityFieldsModule.f90 -o wlOpacityFieldsModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlIOModuleHDF.f90 -o wlIOModuleHDF.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/EOSSource/wlEquationOfStateTableModule.f90 -o wlEquationOfStateTableModule.o
../..//Distributions/Library/wlIOModuleHDF.f90:523:56:
523 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
Warning: Unused variable ‘adims’ declared at (1) [-Wunused-variable]
../..//Distributions/Library/wlIOModuleHDF.f90:521:58:
521 | INTEGER(HID_T) :: attr_id
| 1
Warning: Unused variable ‘attr_id’ declared at (1) [-Wunused-variable]
../..//Distributions/Library/wlIOModuleHDF.f90:522:59:
522 | INTEGER(SIZE_T) :: attr_len
| 1
Warning: Unused variable ‘attr_len’ declared at (1) [-Wunused-variable]
../..//Distributions/Library/wlIOModuleHDF.f90:520:59:
520 | INTEGER(HID_T) :: atype_id
| 1
Warning: Unused variable ‘atype_id’ declared at (1) [-Wunused-variable]
../..//Distributions/Library/wlIOModuleHDF.f90:508:26:
508 | desc_option, unit_option)
| 1
Warning: Unused dummy argument ‘desc_option’ at (1) [-Wunused-dummy-argument]
../..//Distributions/Library/wlIOModuleHDF.f90:508:39:
| 1
Warning: Unused dummy argument ‘unit_option’ at (1) [-Wunused-dummy-argument]
../..//Distributions/Library/wlIOModuleHDF.f90:441:56:
441 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:439:58:
439 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:440:59:
440 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:438:59:
438 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:427:26:
427 | desc_option, unit_option)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:427:39:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:379:56:
379 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:377:58:
377 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:378:59:
378 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:376:59:
376 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:365:61:
365 | ( name, values, group_id, datasize, desc_option, unit_option )
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:365:74:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:333:56:
333 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:331:58:
331 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:332:59:
332 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:330:59:
330 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:319:61:
319 | ( name, values, group_id, datasize, desc_option, unit_option )
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:319:74:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:285:56:
285 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:283:58:
283 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:284:59:
284 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:282:59:
282 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:271:26:
271 | desc_option, unit_option)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:271:39:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:239:56:
239 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:237:58:
237 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:238:59:
238 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:236:59:
236 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:225:62:
225 | ( name, values, group_id, datasize, desc_option, unit_option )
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:225:75:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:190:56:
190 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:188:58:
188 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:189:59:
189 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:187:59:
187 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:176:26:
176 | desc_option, unit_option)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:176:39:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:142:56:
142 | INTEGER(HSIZE_T), DIMENSION(1) :: adims = (/1/)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:140:58:
140 | INTEGER(HID_T) :: attr_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:141:59:
141 | INTEGER(SIZE_T) :: attr_len
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:139:59:
139 | INTEGER(HID_T) :: atype_id
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:128:26:
128 | desc_option, unit_option)
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:128:39:
| 1
../..//Distributions/Library/wlIOModuleHDF.f90:121:36:
121 | SUBROUTINE WriteHeaderHDF( file_id )
| 1
Warning: Unused dummy argument ‘file_id’ at (1) [-Wunused-dummy-argument]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/Library/wlInterpolationModule.F90 -o wlInterpolationModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/EOSSource/wlEOSIOModuleHDF.f90 -o wlEOSIOModuleHDF.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/EOSSource/wlEOSInversionModule.F90 -o wlEOSInversionModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/EOSSource/wlEOSInterpolationModule.f90 -o wlEOSInterpolationModule.o
../..//Distributions/EOSSource/wlEOSIOModuleHDF.f90:300:21:
263 | CALL MPI_BCAST( buffer, i_count, MPI_INTEGER, rootproc, COMMUNICATOR, ierr )
| 2
300 | CALL MPI_BCAST(EOSTable % TS % States(i) % Values(:), EOSTable % nPoints(i), &
| 1
Warning: Type mismatch between actual argument at (1) and actual argument at (2) (REAL(8)/INTEGER(4)).
../..//Distributions/EOSSource/wlEOSIOModuleHDF.f90:14:19:
14 | INTEGER :: hdferr
| 1
Warning: Unused PRIVATE module variable ‘hdferr’ declared at (1) [-Wunused-value]
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:498:85:
493 | DO i = 1, Nrho
| 2
498 | WRITE (*,*) "Repaired =", Repaired(i,j,k), Repaired(i+1,j,k), Repaired(i-1,j,k), &
| 1
Warning: Array reference at (1) out of bounds (0 < 1) in loop beginning at (2)
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:499:46:
492 | DO j = 1, NT
| 2
499 | Repaired(i,j+1,k), Repaired(i,j-1,k), Repaired(i,j,k+1), Repaired(i,j,k-1)
| 1
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:365:29:
365 | ( x1, x2, x3, Coordinate1, Coordinate2, Coordinate3, LogInterp, &
| 1
Warning: Unused dummy argument ‘coordinate1’ at (1) [-Wunused-dummy-argument]
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:365:42:
| 1
Warning: Unused dummy argument ‘coordinate2’ at (1) [-Wunused-dummy-argument]
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:365:55:
| 1
Warning: Unused dummy argument ‘coordinate3’ at (1) [-Wunused-dummy-argument]
../..//Distributions/EOSSource/wlEOSInterpolationModule.f90:365:66:
| 1
Warning: Unused dummy argument ‘loginterp’ at (1) [-Wunused-dummy-argument]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/OpacitySource/wlOpacityTableModule.f90 -o wlOpacityTableModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API ../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90 -o wlOpacityTableIOModuleHDF.o
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:52:19:
52 | INTEGER :: hdferr
| 1
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:990:66:
990 | REAL(dp), DIMENSION(1) :: bufferReal
| 1
Warning: Unused variable ‘bufferreal’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:986:66:
986 | INTEGER(HSIZE_T), DIMENSION(4) :: datasize4d
| 1
Warning: Unused variable ‘datasize4d’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:944:66:
944 | REAL(dp), DIMENSION(1) :: bufferReal
| 1
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:309:53:
309 | INTEGER :: buffer(1)
| 1
Warning: Unused variable ‘buffer’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:306:57:
306 | INTEGER(HSIZE_T) :: datasize4d(4)
| 1
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:313:59:
313 | REAL(dp), DIMENSION(1) :: tempReal
| 1
Warning: Unused variable ‘tempreal’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:311:61:
311 | CHARACTER(LEN=32), DIMENSION(1) :: tempString
| 1
Warning: Unused variable ‘tempstring’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:78:39:
78 | INTEGER :: tempInteger(1)
| 1
Warning: Unused variable ‘tempinteger’ declared at (1) [-Wunused-variable]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:77:38:
77 | CHARACTER(LEN=32) :: tempString(1)
| 1
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:935:35:
935 | SUBROUTINE ReadOpacityTypeEmAbHDF( EmAb, group_id )
Warning: ‘readopacitytypeemabhdf’ defined but not used [-Wunused-function]
../..//Distributions/OpacitySource/wlOpacityTableIOModuleHDF.f90:979:35:
979 | SUBROUTINE ReadOpacityTypeScatHDF( Scat, group_id )
Warning: ‘readopacitytypescathdf’ defined but not used [-Wunused-function]
ar -r libweaklib.a wlKindModule.o wlGridModule.o wlThermoStateModule.o wlDependentVariablesModule.o wlInterpolationUtilitiesModule.o wlInterpolationModule.o wlIOModuleHDF.o wlEquationOfStateTableModule.o wlEOSInversionModule.o wlEOSInterpolationModule.o wlEOSIOModuleHDF.o wlOpacityFieldsModule.o wlOpacityTableModule.o wlOpacityTableIOModuleHDF.o
ar: creating libweaklib.a
cp libweaklib.a ../../../object
cp *.mod ../../../include
+ cd ../../../
running /home/pmanzella/Flash-X-main-cdalton/lib/thornado/build.sh
+ cd source/SandBox/Interface_FLASH
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
rm -f libthornado.a ../../../object/libthornado.a *.mod ../../../include/*.mod *.o *.mod *.i *.s *.lst *.a
+ make -f Makefile.Flash -j8 BUILDFLAG=OPT USE_GPU=FALSE USE_CUDA=FALSE USE_CUBLAS=FALSE USE_HIP=FALSE USE_ROCM=FALSE USE_ONEMKL=FALSE USE_OACC=FALSE USE_OMP_OL=FALSE USE_OMP=FALSE MOMENT_CLOSURE=MINERBO NEUTRINO_MATTER_SOLVER=EMAB TWOMOMENT_ORDER=ORDER_1 MICROPHYSICS=WEAKLIB
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Numbers/KindModule.f90 -o KindModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Units/PhysicalConstantsModule.f90 -o PhysicalConstantsModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/ProgramHeader/ProgramHeaderModule.F90 -o ProgramHeaderModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ArrayUtilitiesModule.F90 -o ArrayUtilitiesModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/QuadratureModule.f90 -o QuadratureModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/DeviceModule.F90 -o DeviceModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/TimersModule.f90 -o TimersModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/LagrangePolynomialsModule.f90 -o LagrangePolynomialsModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/TimersModule_Euler.f90 -o TimersModule_Euler.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90 -o TwoMoment_ClosureModule.o
../..//Modules/Library/DeviceModule.F90:281:19:
281 | INTEGER :: ierr
| 1
Warning: Unused variable ‘ierr’ declared at (1) [-Wunused-variable]
../..//Modules/Library/DeviceModule.F90:279:32:
279 | SUBROUTINE stream_sync( stream )
| 1
Warning: Unused dummy argument ‘stream’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/DeviceModule.F90:238:60:
238 | LOGICAL FUNCTION device_is_present( hostptr, device, bytes )
| 1
Warning: Unused dummy argument ‘bytes’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/DeviceModule.F90:238:53:
| 1
Warning: Unused dummy argument ‘device’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/DeviceModule.F90:238:45:
| 1
Warning: Unused dummy argument ‘hostptr’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/DeviceModule.F90:148:19:
148 | INTEGER :: ierr, myrank, nranks
| 1
../..//Modules/Library/DeviceModule.F90:148:27:
| 1
Warning: Unused variable ‘myrank’ declared at (1) [-Wunused-variable]
../..//Modules/Library/DeviceModule.F90:148:35:
| 1
Warning: Unused variable ‘nranks’ declared at (1) [-Wunused-variable]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/TwoMoment/TwoMoment_TimersModule.F90 -o TwoMoment_TimersModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Units/UnitsModule.f90 -o UnitsModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Mesh/MeshModule.F90 -o MeshModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/LinearAlgebraModule.F90 -o LinearAlgebraModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ReferenceElementModuleX.F90 -o ReferenceElementModuleX.o
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:515:16:
515 | INTEGER :: i
| 1
Warning: Unused variable ‘i’ declared at (1) [-Wunused-variable]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:442:35:
442 | FUNCTION HeatFluxFactor_Scalar( D, FF ) RESULT( HeatFluxFactor )
| 1
Warning: Unused dummy argument ‘d’ at (1) [-Wunused-dummy-argument]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:453:17:
453 | REAL(DP) :: x
| 1
Warning: Unused variable ‘x’ declared at (1) [-Wunused-variable]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:310:36:
310 | FUNCTION EddingtonFactor_Scalar( D, FF ) &
| 1
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:684:2:
684 | FUNCTION ClosurePolynomial_ME_BL_Scalar( X ) &
Warning: ‘closurepolynomial_me_bl_scalar’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:703:2:
703 | FUNCTION ClosurePolynomial_ME_BL_Vector( X ) &
Warning: ‘closurepolynomial_me_bl_vector’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:723:2:
723 | FUNCTION ClosurePolynomial_KE_BL_Scalar( X ) &
Warning: ‘closurepolynomial_ke_bl_scalar’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:741:2:
741 | FUNCTION ClosurePolynomial_KE_BL_Vector( X ) &
Warning: ‘closurepolynomial_ke_bl_vector’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:782:2:
782 | FUNCTION ClosurePolynomialDerivative_ME_CB_Vector( X ) &
Warning: ‘closurepolynomialderivative_me_cb_vector’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:801:2:
801 | FUNCTION ClosurePolynomialDerivative_ME_BL_Scalar( X ) &
Warning: ‘closurepolynomialderivative_me_bl_scalar’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:823:2:
823 | FUNCTION ClosurePolynomialDerivative_ME_BL_Vector( X ) &
Warning: ‘closurepolynomialderivative_me_bl_vector’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:845:2:
845 | FUNCTION ClosurePolynomialDerivative_KE_BL_Scalar( X ) &
Warning: ‘closurepolynomialderivative_ke_bl_scalar’ defined but not used [-Wunused-function]
../..//Modules/TwoMoment/TwoMoment_ClosureModule.F90:864:2:
864 | FUNCTION ClosurePolynomialDerivative_KE_BL_Vector( X ) &
Warning: ‘closurepolynomialderivative_ke_bl_vector’ defined but not used [-Wunused-function]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/PolynomialBasisModuleX_Lagrange.f90 -o PolynomialBasisModuleX_Lagrange.o
../..//Modules/Library/LinearAlgebraModule.F90:1338:43:
1338 | INTEGER :: ierr
| 1
../..//Modules/Library/LinearAlgebraModule.F90:1235:43:
1235 | INTEGER :: ierr
| 1
../..//Modules/Library/LinearAlgebraModule.F90:1153:43:
1153 | INTEGER :: ierr, i
| 1
../..//Modules/Library/LinearAlgebraModule.F90:1148:57:
1148 | SUBROUTINE VectorDotProductBatched( n, x, incx, stridex, y, incy, stridey, batchcount, xy )
| 1
Warning: Unused dummy argument ‘stridex’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/LinearAlgebraModule.F90:1154:49:
1154 | INTEGER(C_INT64_T) :: stridex_64, stridey_64
| 1
Warning: Unused variable ‘stridex_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:1148:75:
| 1
Warning: Unused dummy argument ‘stridey’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/LinearAlgebraModule.F90:1154:61:
| 1
Warning: Unused variable ‘stridey_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:1006:46:
1006 | INTEGER :: ierr, max_mn, min_mn
| 1
../..//Modules/Library/LinearAlgebraModule.F90:943:46:
943 | INTEGER :: ierr, info, max_mn
| 1
../..//Modules/Library/LinearAlgebraModule.F90:844:46:
844 | INTEGER :: ierr, info, i, j, ix
| 1
../..//Modules/Library/LinearAlgebraModule.F90:844:52:
| 1
Warning: Unused variable ‘info’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:838:47:
838 | CHARACTER :: trans
| 1
Warning: Unused variable ‘trans’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:750:46:
750 | INTEGER :: ierr, lenx, leny
| 1
../..//Modules/Library/LinearAlgebraModule.F90:599:54:
599 | INTEGER :: ierr, i, stridea, strideb, strideipiv
| 1
../..//Modules/Library/LinearAlgebraModule.F90:601:60:
601 | INTEGER(C_INT64_T) :: strideP_64
| 1
Warning: Unused variable ‘stridep_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:471:46:
471 | INTEGER :: ierr, i
| 1
../..//Modules/Library/LinearAlgebraModule.F90:473:52:
473 | INTEGER(C_INT64_T) :: stridea_64, strideb_64, stridec_64
| 1
Warning: Unused variable ‘stridea_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:474:51:
474 | INTEGER(C_LONG_LONG) :: stridea_l, strideb_l, stridec_l
| 1
Warning: Unused variable ‘stridea_l’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:473:64:
| 1
Warning: Unused variable ‘strideb_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:474:62:
| 1
Warning: Unused variable ‘strideb_l’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:473:76:
| 1
Warning: Unused variable ‘stridec_64’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:474:73:
| 1
Warning: Unused variable ‘stridec_l’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:371:46:
371 | INTEGER :: ierr
| 1
../..//Modules/Library/LinearAlgebraModule.F90:190:45:
190 | TYPE(C_PTR) :: dat, dbt
| 1
Warning: Unused variable ‘dat’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:190:50:
| 1
Warning: Unused variable ‘dbt’ declared at (1) [-Wunused-variable]
../..//Modules/Library/LinearAlgebraModule.F90:184:52:
184 | INTEGER :: i, j, ierr, info
| 1
../..//Modules/Library/LinearAlgebraModule.F90:184:58:
| 1
../..//Modules/Library/LinearAlgebraModule.F90:146:43:
146 | INTEGER FUNCTION itrans_from_char( ctrans )
| 1
Warning: Unused dummy argument ‘ctrans’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/PolynomialBasisModuleX_Lagrange.f90:238:33:
238 | PURE REAL(DP) FUNCTION Empty( x )
| 1
Warning: Unused dummy argument ‘x’ at (1) [-Wunused-dummy-argument]
../..//Modules/Library/PolynomialBasisModuleX_Lagrange.f90:183:33:
183 | PURE REAL(DP) FUNCTION Unity( x )
| 1
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ReferenceElementModuleE.F90 -o ReferenceElementModuleE.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ReferenceElementModule.F90 -o ReferenceElementModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/UtilitiesModule.F90 -o UtilitiesModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/PolynomialBasisModule_Legendre.f90 -o PolynomialBasisModule_Legendre.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ReferenceElementModuleZ.F90 -o ReferenceElementModuleZ.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Geometry/GeometryFieldsModuleE.F90 -o GeometryFieldsModuleE.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Fields/FluidFieldsModule.F90 -o FluidFieldsModule.o
../..//Modules/Library/PolynomialBasisModule_Legendre.f90:288:38:
288 | PURE REAL(DP) FUNCTION Legendre_0( x )
| 1
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Fields/RadiationFieldsModule.F90 -o RadiationFieldsModule.o
../..//Modules/Geometry/GeometryFieldsModuleE.F90:22:15:
22 | namesGE = [ 'Energy Power 0 ', &
| 1
Warning: CHARACTER expression at (1) is being truncated (44/32) [-Wcharacter-truncation]
../..//Modules/Geometry/GeometryFieldsModuleE.F90:22:63:
| 1
../..//Modules/Geometry/GeometryFieldsModuleE.F90:23:63:
23 | 'Energy Power 1 ', &
| 1
../..//Modules/Geometry/GeometryFieldsModuleE.F90:24:63:
24 | 'Energy Power 2 ', &
| 1
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Opacities/OpacityModule_TABLE.F90 -o OpacityModule_TABLE.o
../..//Modules/Library/UtilitiesModule.F90:152:63:
152 | SUBROUTINE InitializeWeights3D( w1, w2, w3, w3D, w2D_1, w2D_2, w2D_3 )
| 1
Warning: Dummy argument ‘w2d_2’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Library/UtilitiesModule.F90:152:70:
| 1
Warning: Dummy argument ‘w2d_3’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Library/UtilitiesModule.F90:366:2:
366 | FUNCTION MinMod2_Vector( a, b ) &
Warning: ‘minmod2_vector’ defined but not used [-Wunused-function]
../..//Modules/Library/UtilitiesModule.F90:414:2:
414 | FUNCTION MinMod_Vector( a, b, c ) &
Warning: ‘minmod_vector’ defined but not used [-Wunused-function]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Opacities/NeutrinoOpacitiesModule.f90 -o NeutrinoOpacitiesModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Geometry/GeometryFieldsModule.F90 -o GeometryFieldsModule.o
../..//Modules/Opacities/OpacityModule_TABLE.F90:56:7:
56 | dE1, dE2
| 1
Warning: Unused PRIVATE module variable ‘de1’ declared at (1) [-Wunused-value]
../..//Modules/Opacities/OpacityModule_TABLE.F90:56:12:
56 | dE1, dE2
| 1
Warning: Unused PRIVATE module variable ‘de2’ declared at (1) [-Wunused-value]
../..//Modules/Opacities/OpacityModule_TABLE.F90:54:27:
54 | iD_T, iT_T, iY_T, idxE1, idxE2
| 1
Warning: Unused PRIVATE module variable ‘idxe1’ declared at (1) [-Wunused-value]
../..//Modules/Opacities/OpacityModule_TABLE.F90:54:34:
| 1
Warning: Unused PRIVATE module variable ‘idxe2’ declared at (1) [-Wunused-value]
../..//Modules/Opacities/OpacityModule_TABLE.F90:950:58:
950 | SUBROUTINE ComputeScatteringOpacity_NES_TABLE( E, T, Eta, R0_In, R0_Out )
| 1
Warning: Unused dummy argument ‘eta’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:955:17:
955 | INTEGER :: iX
| 1
Warning: Unused variable ‘ix’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:956:40:
956 | REAL(DP), DIMENSION(SIZE(E)) :: LogE
| 1
Warning: Unused variable ‘loge’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:950:65:
| 1
Warning: Dummy argument ‘r0_in’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:950:73:
| 1
Warning: Dummy argument ‘r0_out’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:950:53:
| 1
Warning: Unused dummy argument ‘t’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:21:
907 | ( E, D, T, Y, X1, X2, X3, Sigma )
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:912:40:
912 | REAL(DP), DIMENSION(SIZE(E)) :: LogE
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:46:
| 1
Warning: Dummy argument ‘sigma’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:24:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:31:
| 1
Warning: Unused dummy argument ‘x1’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:35:
| 1
Warning: Unused dummy argument ‘x2’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:39:
| 1
Warning: Unused dummy argument ‘x3’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:907:27:
| 1
Warning: Unused dummy argument ‘y’ at (1) [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:44:
863 | ( E, D, T, Y, X1, X2, X3, Chi )
| 1
Warning: Dummy argument ‘chi’ at (1) was declared INTENT(OUT) but was not set [-Wunused-dummy-argument]
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:21:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:868:40:
868 | REAL(DP), DIMENSION(SIZE(E)) :: LogE
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:24:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:31:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:35:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:39:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:863:27:
| 1
../..//Modules/Opacities/OpacityModule_TABLE.F90:192:35:
192 | INTEGER :: nOpacities, nMoments, nPointsEta, nPointsD, nPointsT, nPointsE
| 1
Warning: Unused variable ‘nmoments’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:192:25:
| 1
Warning: Unused variable ‘nopacities’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:192:57:
| 1
Warning: Unused variable ‘npointsd’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:192:47:
| 1
Warning: Unused variable ‘npointseta’ declared at (1) [-Wunused-variable]
../..//Modules/Opacities/OpacityModule_TABLE.F90:192:67:
| 1
Warning: Unused variable ‘npointst’ declared at (1) [-Wunused-variable]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/PolynomialBasisModule_Lagrange.f90 -o PolynomialBasisModule_Lagrange.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/ReferenceElementModuleX_Lagrange.F90 -o ReferenceElementModuleX_Lagrange.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90 -o EquationOfStateModule_IDEAL.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90 -o EquationOfStateModule_TABLE.o
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:401:33:
401 | PURE REAL(DP) FUNCTION Empty( x )
| 1
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:329:33:
329 | PURE REAL(DP) FUNCTION Unity( x )
| 1
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:209:57:
209 | REAL(DP), DIMENSION(1:nNodesE, 1:nNodesE) :: M_E
| 1
Warning: Unused variable ‘m_e’ declared at (1) [-Wunused-variable]
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:210:58:
210 | REAL(DP), DIMENSION(1:nNodesX(1),1:nNodesX(1)) :: M_X1
| 1
Warning: Unused variable ‘m_x1’ declared at (1) [-Wunused-variable]
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:211:58:
211 | REAL(DP), DIMENSION(1:nNodesX(2),1:nNodesX(2)) :: M_X2
| 1
Warning: Unused variable ‘m_x2’ declared at (1) [-Wunused-variable]
../..//Modules/Library/PolynomialBasisModule_Lagrange.f90:212:58:
212 | REAL(DP), DIMENSION(1:nNodesX(3),1:nNodesX(3)) :: M_X3
| 1
Warning: Unused variable ‘m_x3’ declared at (1) [-Wunused-variable]
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Library/SubcellReconstructionModule.F90 -o SubcellReconstructionModule.o
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Geometry/GeometryComputationModule_XCFC.f90 -o GeometryComputationModule_XCFC.o
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:227:67:
227 | SUBROUTINE ComputeSoundSpeedFromPrimitive_IDEAL_Vector( D, Ev, Ne, Cs )
| 1
Warning: Unused dummy argument ‘ne’ at (1) [-Wunused-dummy-argument]
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:211:67:
211 | SUBROUTINE ComputeSoundSpeedFromPrimitive_IDEAL_Scalar( D, Ev, Ne, Cs )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:144:14:
144 | ( D, Em, Y, P )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:133:57:
133 | SUBROUTINE ComputePressureFromPrimitive_IDEAL_Vector( D, Ev, Ne, P )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:133:65:
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:117:57:
117 | SUBROUTINE ComputePressureFromPrimitive_IDEAL_Scalar( D, Ev, Ne, P )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:117:65:
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:107:7:
107 | ( D, P, Y, Ev )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:107:13:
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:96:7:
96 | ( D, P, Y, Ev )
| 1
../..//Modules/EquationOfState/EquationOfStateModule_IDEAL.F90:96:13:
| 1
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/Euler/Euler_ErrorModule.f90 -o Euler_ErrorModule.o
../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90:19:27:
19 | InitializeEOSInversion, &
| 1
Error: Symbol ‘computetemperaturewith_dey_single_guess_error’ referenced at (1) not found in module ‘wleosinversionmodule’
../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90:20:50:
20 | ComputeTemperatureWith_DEY_Single_Guess_Error, &
| 1
Error: Symbol ‘computetemperaturewith_dey_single_guess_noerror’ referenced at (1) not found in module ‘wleosinversionmodule’
../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90:21:52:
21 | ComputeTemperatureWith_DEY_Single_Guess_NoError, &
| 1
Error: Symbol ‘computetemperaturewith_dey_single_noguess_error’ referenced at (1) not found in module ‘wleosinversionmodule’
../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90:22:52:
22 | ComputeTemperatureWith_DEY_Single_NoGuess_Error, &
| 1
Error: Symbol ‘computetemperaturewith_dey_single_noguess_noerror’ referenced at (1) not found in module ‘wleosinversionmodule’
../..//Modules/EquationOfState/EquationOfStateModule_TABLE.F90:23:54:
23 | ComputeTemperatureWith_DEY_Single_NoGuess_NoError, &
| 1
Error: Symbol ‘computetemperaturewith_dpy_single_noguess_error’ referenced at (1) not found in module ‘wleosinversionmodule’
/opt/ohpc/pub/mpi/mvapich2-gnu12/2.3.7/bin/mpif90 -ggdb -c -O2 -fdefault-real-8 -fdefault-double-8 -Wuninitialized -fallow-argument-mismatch -I../../../../weaklib/include -I/opt/ohpc/pub/libs/gnu12/hdf5/1.14.4/include -DH5_USE_16_API -DMICROPHYSICS_WEAKLIB -DMOMENT_CLOSURE_MINERBO -DNEUTRINO_MATTER_SOLVER_EMAB -DTWOMOMENT_ORDER_1 -DGRAVITY_SOLVER_ -DHYDRO_NONRELATIVISTIC -DHYDRO_RIEMANN_SOLVER_HLL -DTHORNADO_LA_LAPACK -DTHORNADO_GIT_HASH=\"\" -DTHORNADO_GIT_DATE=\"\" -DTHORNADO_GIT_BRANCH=\"\" -DTHORNADO_GIT_URL=\"\" ../..//Modules/TwoMoment/TwoMoment_BoundaryConditionsModule.F90 -o TwoMoment_BoundaryConditionsModule.o
make: *** [Makefile.Flash:171: EquationOfStateModule_TABLE.o] Error 1
make: *** Waiting for unfinished jobs....
../..//Modules/Library/SubcellReconstructionModule.F90:136:36:
136 | INTEGER :: iX1, iX2, iX3, iDOFX, jDOFX, kDOFX, iS
| 1
Warning: Unused variable ‘idofx’ declared at (1) [-Wunused-variable]
../..//Modules/Library/SubcellReconstructionModule.F90:42:20:
42 | INTEGER :: INFO
| 1
../..//Modules/Library/SubcellReconstructionModule.F90:43:27:
43 | INTEGER :: IPIV(nDOFX)
| 1
Warning: Unused variable ‘ipiv’ declared at (1) [-Wunused-variable]
../..//Modules/Library/SubcellReconstructionModule.F90:44:27:
44 | REAL(DP) :: WORK(nDOFX)
| 1
Warning: Unused variable ‘work’ declared at (1) [-Wunused-variable]
../..//Modules/TwoMoment/TwoMoment_BoundaryConditionsModule.F90:599:22:
599 | REAL(DP):: E, Mu_0
| 1
Warning: Unused variable ‘mu_0’ declared at (1) [-Wunused-variable]
../..//Modules/TwoMoment/TwoMoment_BoundaryConditionsModule.F90:152:22:
152 | REAL(DP) :: E_K(2), E_R
| 1
Warning: Unused variable ‘e_k’ declared at (1) [-Wunused-variable]
../..//Modules/TwoMoment/TwoMoment_BoundaryConditionsModule.F90:2182:31:
2182 | SUBROUTINE CheckRealizability(N, G1, V1,iZ2)
Warning: ‘checkrealizability’ defined but not used [-Wunused-function]
A setup internal error has occured, if possible please email the following
debugging info to flash-x-users at lists.cels.anl.gov
Arguments: ['/home/pmanzella/Flash-X-main-cdalton/bin/setup.py', 'Relaxation', '-auto', '-3d', '+cartesian', '+cube16', '+thornado', 'nE=16', 'swE=0', 'nSpecies=6', 'nNodes=2', 'nMoments=4', 'momentClosure=MINERBO', 'thornadoOrder=ORDER_1', '+weaklib', '-parfile=flash.par']
Python Version: 3.9.18
Platform Details: linux
Traceback (most recent call last):
File "/home/pmanzella/Flash-X-main-cdalton/bin/setup.py", line 331, in <module>
raise e
File "/home/pmanzella/Flash-X-main-cdalton/bin/setup.py", line 316, in <module>
main()
File "/home/pmanzella/Flash-X-main-cdalton/bin/setup.py", line 236, in main
generateMakefile(configInfo, machDir)
File "/home/pmanzella/Flash-X-main-cdalton/bin/genFiles.py", line 552, in generateMakefile
flagRedirect = setRedirectFlags('Makefile.h', GVars.buildFlag,
File "/home/pmanzella/Flash-X-main-cdalton/bin/genFiles.py", line 671, in setRedirectFlags
libFlags = libConfigInfo.getLibFlags(lib, buildFlag=buildFlag,
File "/home/pmanzella/Flash-X-main-cdalton/bin/libUtils.py", line 146, in getLibFlags
self.makeBinary(libDir,base,makefilename)
File "/home/pmanzella/Flash-X-main-cdalton/bin/libUtils.py", line 247, in makeBinary
status = subprocess.check_call('./build.sh', shell=False)
File "/usr/lib64/python3.9/subprocess.py", line 373, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command './build.sh' returned non-zero exit status 2.
More information about the Flash-X-users
