[Flash-X-users] Getting Flash-X to work
kiyarash Taghiniyarami
kiyarash.niyarami at gmail.com
Mon Aug 26 14:17:20 CDT 2024
>From the path, it seems it is due to EOS calling in Thornado. Thornado
tries to call wlEOSInversionModule.F90 from
lib/weaklib/souce/Distributions/EOSSource. make sure
wlEOSInversionModule.F90 is present in that directory.
On Mon, Aug 26, 2024 at 10:23 PM Peter Manzella <peter.manzella at maine.edu>
wrote:
> OK, that makes more sense, I'll need to make sure those are in the file,
> not command line. I went to setup after adding those, and have this error,
> its related to equation of state, and I haven't been able to find anything
> in documentation about it.
> [image: image.png]
> This is the sort of thing that is frustrating, not being able to find
> where I need to look to troubleshoot. I tried using grep to find it, I've
> looked in the documentation link you sent me (I already knew about that,
> but it wasn't helpful beyond the quick start), but couldn't find it. Is
> this more of a thornado issue? Cause like I said I'm not super acquainted
> with large codes that require so many moving pieces.
> On Mon, Aug 26, 2024 at 2:28 PM kiyarash Taghiniyarami <
> kiyarash.niyarami at gmail.com> wrote:
>> Dear Peter,
>> These are not for command line (If you mean "command line" as setup for
>> configuring a new run).
>> Before setup you need to make a directory in the Simulation unit
>> (/source/Simulation/SimulationMain). In that directory you need some codes
>> such as Simulation_data.F90, Simulation_init.F90, Simulation_initBlock.F90,
>> and etc.
>> Say you need the "Half" variable in the Simulation_initBlock.F90. you can
>> call it by KindModule from Thornado if you write the following in that
>> fortran code:
>> Use KindModule, only: Half
>> so you can use the "Half" anywhere in that Simulation_initBlock.F90. It
>> has nothing to do with typing in the command line and hitting enter.
>> If I understand correctly what you mean, there are some setup variables
>> you can type in the command line (such as nxb,nyb, swE,nE and etc.) which
>> are different from modules. setup variables can be set up in Config files
>> in any physics subdirectories.
>> There is documentation for Flashx as well:
>> https://urldefense.us/v3/__https://flash-x.github.io/Flash-X-docs/*__;Iw!!G_uCfscf7eWS!Y30QGbrpRlG8_j537Y5ALnx2_5HtemjHNcWoV8A9SmlscTRBVVHwb85psYx5owKplriHOQpq80sa4KKTee0CiBpr3dw5ImSKUDctrLhE$
>> Kind regards,
>> Kiya
> Peter Manzella
> PhD Candidate, Department of Physics and Astronomy
> 309 Bennett Hall
> University of Maine
> “If you run out of ideas follow the road; you'll get there.” – Edgar Allan
> Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240826/43492c2a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240826/43492c2a/attachment-0001.png>
More information about the Flash-X-users
