[Flash-X-users] Getting Flash-X to work
Peter Manzella peter.manzella at maine.edu
Fri Aug 23 14:28:13 CDT 2024
Thank you. I've been trying to work through, step by step, looking at
errors that come up and trying to find out what I need to look at next to
fix them. I have Thornado and that stuff figured out. I know my makefile.h
is good, I worked with the cluster admin to get that all set and in order.
But of late the errors I am getting...I can not find any documentation or
can find them given the error message.  Like this,
[image: image.png]
I can't find anything on how to approach this, I don't have a strong
background in dealing with large codes like Flash-X, so getting this far
has been extremely difficult.
I understand that it is a beast of a simulation, and that it can be
frustrating, I have been able to get through the majority of what I need to
get done with little resistance, but this is providing resistance that I
need to seek more outside help/assistance, hence me reaching out via this
email chain. I am not expecting this to be extremely easy, but was also
hoping it wouldn't be something that requires me to extend my degree more
than it already has. Any help is appreciated! Thank you again in advance!
On Fri, Aug 23, 2024 at 2:30 PM kiyarash Taghiniyarami <
kiyarash.niyarami at gmail.com> wrote:
> Dear Peter,
> Following are the steps I have gone through and hope it will help you:
> 1-The CCSN is a really diverse issue consisting of
> Radiation+Hydro+Grivity+EOS+Nuclear+etc physics.
> To focus on the FlashX you can run just core collapse before the bounce in
> 1D then extend it to 2D (source/Simulation/SimulationMain/CCSN_WL).
> working on it and extending it to 2D with weaklib would help you a lot to
> understand how Flashx works (without neutrinos).
> 2-For the radiation part try to read the https://urldefense.us/v3/__https://arxiv.org/abs/2102.02186__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmXp_ZI64$
> and https://urldefense.us/v3/__https://trace.tennessee.edu/utk_graddiss/7742/__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmSijw6be$  and you can watch the
> series of https://urldefense.us/v3/__https://www.youtube.com/watch?v=tK1HbAiCPuw__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmT96mSjz$   for introduction
> of DG method and then download thornado (
> https://urldefense.us/v3/__https://github.com/endeve/thornado__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmSYWayvu$ ) and get deep into it (I mean check
> its all subdirectories out to understand how it works) and run the tests
> (such as sine wave streaming, damping, diffusion)
> 3- After that you can run the test of sine streaming, doppler shift,
> relaxation and deleptonization wave test in Flashx
> 4- Then you can start the run of
> /source/Simulation/SimulationMain/CCSN_WL_Transport
> There lots of detail in each step you have to take for example digging
> into weaklib eos and hybrid eos and understanding of nuclear burning (
> https://urldefense.us/v3/__https://arxiv.org/abs/astro-ph/0509698__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmQpggmcN$ ).
> Btw for compilation and setup errors and making true makfile.h you have to
> get help from someone in your university which knows the cluster(you work
> with) well.
> This topic you are working on is full of frustration. Do not get
> disappointed.
> P.S. Do not forget to use FlashX github, especially its commits and
> branches which could take you to earlier development of the code stages
> with the collaborators comments which are truly helpful.
> Kind Regards,
> Kiya
> On Fri, Aug 23, 2024 at 8:17 PM Peter Manzella <peter.manzella at maine.edu>
> wrote:
>> Hi, I have been having trouble getting Flash-X to run properly on my
>> university's computer cluster, but no matter what I have tried, errors keep
>> popping up. I can go into detail, but I don't know where to start, any help
>> would be appreciated.
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> Hi,
>> I have tried to troubleshoot and debug as much as I can, but I am still
>> lost, and a bit frustrated that I cannot get Flash-X to work properly. Is
>> there somewhere else I should be asking for help? My "end goal" is to use
>> Flash-X for 2d core collapse simulations, but when I originally contacted
>> this email chain, someone suggested I start with something simpler, which I
>> have been trying to.
>> Peter Manzella
>> PhD Candidate, Department of Physics and Astronomy
>> 309 Bennett Hall
>> University of Maine
>> “If you run out of ideas follow the road; you'll get there.” – Edgar
>> Allan Poe
>> Flash-X-users mailing list
>> Flash-X-users at lists.cels.anl.gov
>> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!daO1sKEzfp3vyTmzQ96G7q_t366_THX9wGjsvDVbYdAiD3C_M1lSJSkzTAdapeNvtluzH_V37wglPqxlXxQ47ggpudW0lEUxmcr5Qngd$
Peter Manzella
309 Bennett Hall
University of Maine
“If you run out of ideas follow the road; you'll get there.” – Edgar Allan
Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240823/13372852/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240823/13372852/attachment-0001.png>
More information about the Flash-X-users mailing list
