[Flash-X-users] Setup Internal Error
kiyarash Taghiniyarami kiyarash.niyarami at gmail.com
Tue Apr 23 12:28:59 CDT 2024
Dear Peter,
Setup, compilation and running 2d CCSN at the first step needs too many
setups, libraries and details (thornad, Weaklib, Xnet and etc). I am not
sure if you setup everything correctly from the first as you have problem
in setup command so I share what I went through as follows:
 besides MPI, HDF5,Zlib, NCMPI you have installed in FLASH, for Flash-X you
may also need LAPACK, BLAS, MA28 and stdcxx to be installed and after that
in the directory of sites (Flash-X/sites) you have to make your own machine
directory (if is not set by default sites) then make the Makefile.h.
I will attach my own Makefile which is based on my laptop that may help you.
After all these steps, my suggestion is to run the Relaxation and
DeleptonizationWave test. After successful runs, then you may go through a
complex run such as 2d CCSN. I am not sure how much time you do have but
fixing all setups mentioned above may take you at least two weeks (because
in every step you will face erros you need to resolve).
If you really want to understand what you are going through you need at
least a grasp on thornado lib (
https://urldefense.us/v3/__https://github.com/endeve/thornado/tree/883a6feefc2af3c14fafd7dd011f2cf6d4a66f07__;!!G_uCfscf7eWS!e0jSlyGJUmNjk0uM7BtwDH05f29eYR23kHJZQRA-XTdaZIBJBi47ozUzW3tb4RFcV6vBMJVU3gxMSr3nAHoL7RjfoF0pbxGGYsWXlKha$
check the link and in docs you can find the details of Neutrino Two moment
scheme.
Best,
Kiya
On Tue, Apr 23, 2024 at 5:56 PM Peter Manzella <peter.manzella at maine.edu>
wrote:
> Hi, I've been trying to get a 2-dimensional CCSN simulation running, and
> I've run into some problems, some that I could figure out how to fix, but I
> keep hitting a wall on some, as I can't find documentation on how to
> troubleshoot
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Hi,
> I've been trying to get a 2-dimensional CCSN simulation running, and I've
> run into some problems, some that I could figure out how to fix, but I keep
> troubleshoot some of them, particularly this one, where it points to email
> here,
> [image: image.png]
> Any help would be appreciated, I had tried for months to get 2d
> simulations to work with FLASH, before someone suggested to try Flash-X.
> Peter Manzella
> PhD Candidate, Department of Physics and Astronomy
> 309 Bennett Hall
> University of Maine
> “If you run out of ideas follow the road; you'll get there.” – Edgar Allan
> Poe
> Flash-X-users mailing list
> Flash-X-users at lists.cels.anl.gov
> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!e0jSlyGJUmNjk0uM7BtwDH05f29eYR23kHJZQRA-XTdaZIBJBi47ozUzW3tb4RFcV6vBMJVU3gxMSr3nAHoL7RjfoF0pbxGGYtkxokRZ$
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240423/3e2d10cc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240423/3e2d10cc/attachment-0001.png>
Type: text/x-chdr
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240423/3e2d10cc/attachment-0001.bin>
More information about the Flash-X-users mailing list
