[Flash-X-users] Problem of running Relaxation (two moment benchmark)
kiyarash Taghiniyarami kiyarash.niyarami at gmail.com
Mon Apr 22 02:02:36 CDT 2024
Yup, thanks
On Mon, 22 Apr 2024, 10:25 Dubey, Anshu, <adubey at anl.gov> wrote:
> So your problem is solved?
> *From: *kiyarash Taghiniyarami <kiyarash.niyarami at gmail.com>
> *Date: *Monday, April 22, 2024 at 1:28 PM
> *To: *Dubey, Anshu <adubey at anl.gov>, flash-x-users at lists.cels.anl.gov <
> flash-x-users at lists.cels.anl.gov>
> *Subject: *Re: [Flash-X-users] Problem of running Relaxation (two moment
> benchmark)
> Dear Anshu, After checking the logfile, I found it was due to the weaklib
> opacity tables path in flash. par which needed to be corrected. Thanks.
> Kiya On Mon, 22 Apr 2024, 04: 39 Dubey, Anshu, <adubey@ anl. gov> wrote:
> Can you send us the
> ZjQcmQRYFpfptBannerStart
> *This Message Is From an External Sender *
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Dear Anshu,
> After checking the logfile, I found it was due to the weaklib opacity
> tables path in flash.par which needed to be corrected.
> Thanks.
> Kiya
> On Mon, 22 Apr 2024, 04:39 Dubey, Anshu, <adubey at anl.gov> wrote:
> Can you send us the log file and setup line for what you were trying to
> do? We need to be able to reproduce your problem.
> Best,
> Anshu
> *From: *Flash-X-users <flash-x-users-bounces at lists.cels.anl.gov> on
> behalf of kiyarash Taghiniyarami <kiyarash.niyarami at gmail.com>
> *Date: *Monday, April 22, 2024 at 4:08 AM
> *To: *flash-x-users at lists.cels.anl.gov <flash-x-users at lists.cels.anl.gov>
> *Subject: *[Flash-X-users] Problem of running Relaxation (two moment
> benchmark)
> Dear users, I tried to run the relaxation  for Neutrino statinary state in
> 1D with 16 nxb test but after running it I face the following problem:
> mpirun -np 8 ./flashx: --------------------------------------------- Source
> terms initialized Using
> Dear users,
> I tried to run the relaxation  for Neutrino statinary state in 1D with 16
> Source terms initialized
>  Using Thornado Relaxation setting to initial radiation field ...
>  [rho, T, Ye]:   1.032E+12   8.805E+10   1.347E-01
>   iteration, no. not moved =            0           0
>  refined: total leaf blocks =           16
>  refined: total blocks =           16
>  [amr_morton_process]: Initializing surr_blks using standard orrery
> implementation
>  INFO: Grid_fillGuardCells is ignoring masking.
>   Finished with Grid_initDomain, no restart
>  Ready to call Hydro_init
>  Hydro initialized
>  Gravity initialized
>  Initial dt verified
>  arrays freed
>  *** Wrote checkpoint file to relaxation_hdf5_chk_0000 ****
>  *** Wrote plotfile to relaxation_hdf5_plt_cnt_0000 ****
>  Initial plotfile written
>  Driver init all done
> Program received signal SIGSEGV: Segmentation fault - invalid memory
> reference.
> Backtrace for this error:
> #0  0x7fd0421afd11 in ???
> #1  0x7fd0421aeee5 in ???
> #2  0x7fd041e7408f in ???
> can anyone help me what is the issue with that?
> Best,
> Kiya
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240422/1dd3330e/attachment-0001.html>
More information about the Flash-X-users mailing list
