[Flash-X-users] Run on 2 out of 8 CPU(cores)
kiyarash Taghiniyarami kiyarash.niyarami at gmail.com
Mon Nov 4 00:37:49 CST 2024
Dear users,
I am running core collapse SN in 1D with the attached parfile where 5
opacity and one EOS hdf5 files are being used simultaneously. When I try to
run it on a 8 CPU core PC, it just runs  with the 2 out of 8 cores where
each of them uses 26.9% of memory (top command screenshot is attached).
The system RAM is 8G. My question is how can I get all the CPU cores to run
the problem? Do you think increasing RAM would help to get more CPU cores
to run the problem?
P.S. Lowering opacity files from 5 to 3 would also help me to get the run
with 4 CPU cores, is there any way to monitor on how the system RAM or
cache handling to open hdf5 files while running the problem?
Best,
Kiya
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20241104/a582c3de/attachment-0001.html>
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20241104/a582c3de/attachment-0001.obj>
Name: Screenshot from 2024-11-04 00-18-03.png
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20241104/a582c3de/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20241104/a582c3de/attachment-0003.png>
More information about the Flash-X-users mailing list
