[Flash-X-users] Setup Internal Error
Peter Manzella peter.manzella at maine.edu
Thu May 30 13:02:41 CDT 2024
It's been a while, some back and forth with the sysadmin for the cluster
that I am using, and we finally had a chance to get to work on it,
DeleptonizationWave is not setting up fully, it stops with these errors,
[image: Capture.PNG]
Any advice is appreciated
On Tue, Apr 23, 2024 at 1:29 PM kiyarash Taghiniyarami <
kiyarash.niyarami at gmail.com> wrote:
> Dear Peter,
> Setup, compilation and running 2d CCSN at the first step needs too many
> setups, libraries and details (thornad, Weaklib, Xnet and etc). I am not
> sure if you setup everything correctly from the first as you have problem
> in setup command so I share what I went through as follows:
>  besides MPI, HDF5,Zlib, NCMPI you have installed in FLASH, for Flash-X
> you may also need LAPACK, BLAS, MA28 and stdcxx to be installed and after
> that in the directory of sites (Flash-X/sites) you have to make your own
> machine directory (if is not set by default sites) then make the Makefile.h.
> I will attach my own Makefile which is based on my laptop that may help
> you.
> After all these steps, my suggestion is to run the Relaxation and
> DeleptonizationWave test. After successful runs, then you may go through a
> complex run such as 2d CCSN. I am not sure how much time you do have but
> fixing all setups mentioned above may take you at least two weeks (because
> in every step you will face erros you need to resolve).
> If you really want to understand what you are going through you need at
> least a grasp on thornado lib (
> https://urldefense.us/v3/__https://github.com/endeve/thornado/tree/883a6feefc2af3c14fafd7dd011f2cf6d4a66f07__;!!G_uCfscf7eWS!ZiEJhT4Em_XhlUZcA6m6HY7RrwQSGPkn3TZTP08_rtYG4uR64A3GaFQAKZxl1you5ADH4c3yiTozBnxkEcAxNZjZSHG6E6C5gYmzCHjC$
> check the link and in docs you can find the details of Neutrino Two moment
> scheme.
> Best,
> Kiya
> On Tue, Apr 23, 2024 at 5:56 PM Peter Manzella <peter.manzella at maine.edu>
> wrote:
>> Hi, I've been trying to get a 2-dimensional CCSN simulation running, and
>> I've run into some problems, some that I could figure out how to fix, but I
>> keep hitting a wall on some, as I can't find documentation on how to
>> troubleshoot
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> Hi,
>> I've been trying to get a 2-dimensional CCSN simulation running, and I've
>> run into some problems, some that I could figure out how to fix, but I keep
>> troubleshoot some of them, particularly this one, where it points to email
>> here,
>> [image: image.png]
>> Any help would be appreciated, I had tried for months to get 2d
>> simulations to work with FLASH, before someone suggested to try Flash-X.
>> Peter Manzella
>> PhD Candidate, Department of Physics and Astronomy
>> 309 Bennett Hall
>> University of Maine
>> “If you run out of ideas follow the road; you'll get there.” – Edgar
>> Allan Poe
>> Flash-X-users mailing list
>> Flash-X-users at lists.cels.anl.gov
>> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!ZiEJhT4Em_XhlUZcA6m6HY7RrwQSGPkn3TZTP08_rtYG4uR64A3GaFQAKZxl1you5ADH4c3yiTozBnxkEcAxNZjZSHG6E6C5gdGrc8s6$
Peter Manzella
309 Bennett Hall
University of Maine
“If you run out of ideas follow the road; you'll get there.” – Edgar Allan
Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240530/9979ce04/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240530/9979ce04/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240530/9979ce04/attachment-0003.png>
More information about the Flash-X-users mailing list
