[Flash-X-users] Setup Errors
Peter Manzella peter.manzella at maine.edu
Sat Jun 22 11:04:08 CDT 2024
I've done some digging into the files that are referenced in the errors
below, and have found nothing that was helpful enough for me to be able to
fix them and get Flash-X to work. I am at a loss as to what to do, I was
suggested to use Flash-X as it was more in tune with what I wanted to do.
Here are the errors that come up,
[image: unnamed.png]
and here is the debugging info that it says to share,
any advice is welcome. My "end goal" is to use Flash-X for 2d core collapse
simulations, but when I originally emailed this chain, I was advised to
start smaller, so I started with the Deleptonization wave.
Peter Manzella
PhD Candidate, Department of Physics and Astronomy
309 Bennett Hall
University of Maine
“If you run out of ideas follow the road; you'll get there.” – Edgar Allan
Poe
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240622/5a2ab448/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240622/5a2ab448/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240622/5a2ab448/attachment-0003.png>
More information about the Flash-X-users mailing list
