[Flash-X-users] Getting Flash-X to work
kiyarash Taghiniyarami kiyarash.niyarami at gmail.com
Fri Aug 23 13:30:23 CDT 2024
Dear Peter,
Following are the steps I have gone through and hope it will help you:
1-The CCSN is a really diverse issue consisting of
Radiation+Hydro+Grivity+EOS+Nuclear+etc physics.
To focus on the FlashX you can run just core collapse before the bounce in
1D then extend it to 2D (source/Simulation/SimulationMain/CCSN_WL).
working on it and extending it to 2D with weaklib would help you a lot to
understand how Flashx works (without neutrinos).
2-For the radiation part try to read the https://urldefense.us/v3/__https://arxiv.org/abs/2102.02186__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutUKwFn4o$
and https://urldefense.us/v3/__https://trace.tennessee.edu/utk_graddiss/7742/__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutSEMwwHO$  and you can watch the
series of https://urldefense.us/v3/__https://www.youtube.com/watch?v=tK1HbAiCPuw__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutT2tS7iT$   for introduction of
DG method and then download thornado (https://urldefense.us/v3/__https://github.com/endeve/thornado__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutSZl6Ofh$ )
and get deep into it (I mean check its all subdirectories out to understand
how it works) and run the tests (such as sine wave streaming, damping,
diffusion)
3- After that you can run the test of sine streaming, doppler shift,
relaxation and deleptonization wave test in Flashx
4- Then you can start the run of
/source/Simulation/SimulationMain/CCSN_WL_Transport
There lots of detail in each step you have to take for example digging into
weaklib eos and hybrid eos and understanding of nuclear burning (
https://urldefense.us/v3/__https://arxiv.org/abs/astro-ph/0509698__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutZSKvh86$ ).
Btw for compilation and setup errors and making true makfile.h you have to
get help from someone in your university which knows the cluster(you work
with) well.
This topic you are working on is full of frustration. Do not get
disappointed.
P.S. Do not forget to use FlashX github, especially its commits and
branches which could take you to earlier development of the code stages
with the collaborators comments which are truly helpful.
Kind Regards,
Kiya
On Fri, Aug 23, 2024 at 8:17 PM Peter Manzella <peter.manzella at maine.edu>
wrote:
> Hi, I have been having trouble getting Flash-X to run properly on my
> university's computer cluster, but no matter what I have tried, errors keep
> popping up. I can go into detail, but I don't know where to start, any help
> would be appreciated.
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Hi,
> I have tried to troubleshoot and debug as much as I can, but I am still
> lost, and a bit frustrated that I cannot get Flash-X to work properly. Is
> there somewhere else I should be asking for help? My "end goal" is to use
> Flash-X for 2d core collapse simulations, but when I originally contacted
> this email chain, someone suggested I start with something simpler, which I
> have been trying to.
> Peter Manzella
> PhD Candidate, Department of Physics and Astronomy
> 309 Bennett Hall
> University of Maine
> “If you run out of ideas follow the road; you'll get there.” – Edgar Allan
> Poe
> Flash-X-users mailing list
> Flash-X-users at lists.cels.anl.gov
> https://urldefense.us/v3/__https://lists.cels.anl.gov/mailman/listinfo/flash-x-users__;!!G_uCfscf7eWS!b089MiYCR5YM0PYzTWI7F4EXyszI-z90J5N0B-rsbBz5aMxt87VCa5YtzTPr0Q-Qu-MooOgQ0CcnoT2X5S7MErPX18CTQGqutSn-pF8b$
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20240823/c22dce8e/attachment.html>
More information about the Flash-X-users mailing list
