[Flash-X-users] CCSN_WL setup problem
Dhruv, Akash Vijaykumar adhruv at anl.gov
Fri Jun 24 19:05:52 CDT 2022
Hello Colter,
Do you still need help with this issue? If so what site file are you using? It looks like the setup tool is unable to find debug flags in the site Makefile.
Akash
On Jun 22, 2022, at 8:43 PM, Richardson, Colter <cricha80 at vols.utk.edu> wrote:
To whom it may concern,
I am attempting to set up the CCSN_WL simulation with the -debug option enabled durring setup, and I get the following error message.
A setup internal error has occured, if possible please email the following
debugging info to flash-x-users at lists.cels.anl.gov<mailto:flash-x-users at lists.cels.anl.gov>
Arguments: ['/home/colter/Flash-X/bin/setup.py', 'CCSN_WL', '-auto', '-1d', '+spherical', '-objdir=ccsn1d_wl', '-nxb=16', 'threadBlockList=False', '+pm4dev', '+hdf5', 'threadWithinBlock=False', '+newMpole', '+uhd', '-debug', '+mode1', '-parfile=ccsn1d.par']
Python Version: 3.8.10
Platform Details: linux
Traceback (most recent call last):
  File "/home/colter/Flash-X/bin/setup.py", line 317, in <module>
    raise e
  File "/home/colter/Flash-X/bin/setup.py", line 302, in <module>
    main()
  File "/home/colter/Flash-X/bin/setup.py", line 222, in main
    generateMakefile(configInfo, machDir)
  File "/home/colter/Flash-X/bin/genFiles.py", line 539, in generateMakefile
    flagRedirect = setRedirectFlags('Makefile.h', GVars.buildFlag,
  File "/home/colter/Flash-X/bin/genFiles.py", line 658, in setRedirectFlags
    libFlags = libConfigInfo.getLibFlags(lib, buildFlag=buildFlag,
  File "/home/colter/Flash-X/bin/libUtils.py", line 145, in getLibFlags
    self.makeBinary(libDir,base,makefilename)
  File "/home/colter/Flash-X/bin/libUtils.py", line 245, in makeBinary
    status = subprocess.check_call('./build.sh', shell=False)
  File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command './build.sh' returned non-zero exit status 2.
Oddly, when I do not include the -debug flag, the simulation works perfect.
I have also included the git diff below so you can see the changes.
diff --git a/bin/setup.py b/bin/setup.py
index 4cc5d224..16a5e97a 100755
--- a/bin/setup.py
+++ b/bin/setup.py
@@ -1,4 +1,4 @@
-#!/usr/bin/env python
+#!/usr/bin/env python3
 import os, sys, string, re, time, shutil, types, glob, socket, math
diff --git a/lib/thornado/source b/lib/thornado/source
index 63bbac76..fa3baef7 160000
--- a/lib/thornado/source
+++ b/lib/thornado/source
@@ -1 +1 @@
-Subproject commit 63bbac76b29c56b55402950d703680a59c06f2b9
+Subproject commit fa3baef76c73cdb72e5d502fdd4834e2bf5ba709
diff --git a/source/Grid/GridMain/AMR/Paramesh4/PM4_package b/source/Grid/GridMain/AMR/Paramesh4/PM4_package
index b277e6d4..b13a873e 160000
--- a/source/Grid/GridMain/AMR/Paramesh4/PM4_package
+++ b/source/Grid/GridMain/AMR/Paramesh4/PM4_package
@@ -1 +1 @@
-Subproject commit b277e6d48ec98c23669b07d2e72624a1122d0252
+Subproject commit b13a873e10a4e9757eb0e64075f2ffe6fdb2acfe
diff --git a/source/Simulation/SimulationMain/CCSN_WL/Config b/source/Simulation/SimulationMain/CCSN_WL/Config
index 8beb1a2a..648b2719 100644
--- a/source/Simulation/SimulationMain/CCSN_WL/Config
+++ b/source/Simulation/SimulationMain/CCSN_WL/Config
@@ -4,7 +4,7 @@ REQUIRES Driver
 REQUIRES Grid
 REQUIRES physics/Hydro/HydroMain
 REQUIRES physics/Eos/EosMain/WeakLib
-REQUESTS physics/sourceTerms/Burn/BurnMain/nuclearBurn
+#REQUESTS physics/sourceTerms/Burn/BurnMain/nuclearBurn
 REQUESTS physics/Gravity/GravityMain/Poisson/Multipole
 # params for 1D initialization
Thank you,
Colter Richardson
University of Tennessee, Knoxville
Physics Graduate Student
cricha80 at vols.utk.edu<mailto:cricha80 at vols.utk.edu>
Flash-X-users mailing list
Flash-X-users at lists.cels.anl.gov
https://lists.cels.anl.gov/mailman/listinfo/flash-x-users
URL: <http://lists.cels.anl.gov/pipermail/flash-x-users/attachments/20220625/975a0ed0/attachment.html>
More information about the Flash-X-users mailing list
